Rotating Force
    • Juan Pablo Aruchari Flores
      I already carried out several tests but when I want to configure the rotation force with a mass imbalance I use a remote point but the following message appears and I cannot continue.... how to correct the message: "the axis of the rotational force must be oriented on the global axis". ninguna
    • peteroznewman
      • The axis of the Rotating Force should coincide with or be parallel to one of the Global Coordinate (X, Y, or Z) axes.
      • You don't show a Global Axis Triad in your image. If the geometry does not have the axis of rotation parallel with a Global Coordinate axis, open the geometry in SpaceClaim and use the Move tool to orient the axis of rotation to be parallel with a global axis.
      Yes you are very right, thank you very much for the observation and greetings from Bolivia
