December 20, 2022 at 10:40 am
Jamie Allen
SubscriberHello, I am currently doing a sloshing tank simulation however I need to have the tank rotating about the x axis at a set sinusoidal motion; then in the z axis in a different set sinusoidal motion. Each one id easy to do individually by setting the rotational velocity about a certaint axis but I am unable to set them both within ithe same simulation. Any help will be greatly appreciated.
Jamie
December 20, 2022 at 1:16 pm
C N
Ansys EmployeeHello,
I recommend you to use the multiple reference frame model for your simulation. For further understaning please refer this link
10.3. Flow in Multiple Moving Reference Frames (ansys.com)
If you cannot access this link kindly refer to this link
Using Help with links (ansys.com)
Thanks
2666
2120
1349
1132
461
