February 8, 2021 at 5:21 am
devanshchoksi
SubscriberI have designed a turbine with similar characteristics to a wind turbine. I am trying to achieve the following:n1. rotate the turbine from the air that is hitting itn2. Calculate power/torquenI am using Fluent to run the analysisn -
February 8, 2021 at 10:59 am
Ansys EmployeeHave a look on here, there are several people doing much the same. VAWT and HAWT may be good key words if turbine returns too many results. Note, you will need a relationship between force on the blades and rotation speed as an input: CFD won't give you all the data without some good boundary conditions. n -
February 10, 2021 at 5:52 pm
atefhimself
SubscriberI have the exact same request, could you please tell me if you found the answer n -
February 10, 2021 at 9:53 pm
YasserSelima
SubscribernYou will need to use dynamic mesh and write a UDF using Define_CG_MOTION or SDOF .. the function would calculate the moment on the turbine and provide the solver with the new rotational speed in the next time step. n
5172
3275
2453
