3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
rotating wall in a CHT simulation 2023 R2
    • Peter Schack
      What is the right way to generate a rotating wall in 2023 R2. In 2023 R1 I define an rotating wall and the software handle both, the Conducting Non-Slip Wall (default) AND the manualy defined Rotating Wall in a right way. (Massage that the Overlapping will be ignored) If I load my Model in 2023 R2 a massage that this "Overlapping" is not permissible. It is not possible to start the solve.
    • Devendra Badgujar
      Forum Moderator
      Hello Peter,
      Can you please share the image of the message to understand this better? Also, does this overlapping conditon conflicts with any connections or interfaces?
      Devendra
    • Peter Schack
      If I prevent the surfaces from "conducting Non-Slip Wall" it is running, but without the CHT effect. The rotating wall options are only insulatet, convection and so on, but NO CHT effect. :-(
    • Peter Schack
      The message of 2023 R1 looks so, and the rotating and CHT effekt work well.
    • Devendra Badgujar
      Forum Moderator
      Hello Peter,
      Thanks for sharing the image. Let me qucikly check this with the team and get back to you.
      Devendra
    • Peter Schack
      Thanks for the quick turnaround 👍
    • Devendra Badgujar
      Forum Moderator
      Hello Peter,
      Discussing through Service request, closing this to avoid duplication.
      Devendra
Viewing 6 reply threads
  • The topic ‘rotating wall in a CHT simulation 2023 R2’ is closed to new replies.
