May 12, 2022 at 1:05 pm
tim.dukes
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi Support,
Â
If I'm trying to simulate the effect centrifugal fan can this be done by using the rotating wall condition or is this not possible in Discovery?
Â
In the model attached I have a simple volume with a rotating wall on a cylindrical face.
Â
Have you any examples of a rotating wall in a model?
Â
Help files aren't that useful and I'm not sure the results I am getting in this example are functioning as expected.
May 12, 2022 at 2:07 pm
Subashni Ravichandran
Ansys EmployeeHello Tim Dukes
Swirling flow only adds a rotational velocity to flow inlet.Â
Let me check the model you have shared and get back to you.
May 13, 2022 at 12:21 pm
Ansys EmployeeTim Dukes
Apologies for the misunderstanding. I thought you were simulating Swirling flow.
Rotating wall gives the specified rotational velocity on the wall face.Â
I don't think it is a good approximation for a centrifugal fan. -
May 13, 2022 at 2:29 pm
3730
2570
1783
1236
594
