Rotation of a flexible body
    • ewold
      The problem I am working on is the following:
      I have a solid cylindrical structure that encases an irregularly shaped volume of fluid. Within that fluid, there is an irregularly shaped solid held in suspension. I wish to apply a rotational load to the outer solid body and use a FSI to visualize the effects of that load on the fluid flow, and then in turn on the inner solid body.
      As far as I am aware, the rotational velocity/acceleration loads are only possible with rigid bodies. How do I go about introducing a rotation to the system without getting excessive distortion errors? Thanks.
    • Sandeep Medikonda
      Hi ewold,
        It can be done by specifying remote points. Check out this useful article that describes how to do this.
      Sandeep
    • Ashish Kumar
      Forum Moderator
      One more way is use of general joint. Free all the DOFs for the joint and then measure the relevant rotation.
