Discovery Import
Discovery Import
Rotation of sheet metal unfolded part in drawing sheet generates wrong dimensions
    • ventura
      here the error.
      Try to unfold a part and put it into a drawing sheet. Then rotate the canvas and as you can see X dimension and Y dimension are wrong (not rotate but the value are the same).
      In example: X (width) is 81, rotating the diagonal is 81, then rotating 90° the height isn't 81...
    • Charudatta Bandgar
      Hello DrkAngl
      Thanks for bringing it to our notice, let me check if something similar was raised earlier and if there is any workaround for it. I will get back to you.
      Regards.
    • rg
      Hello Charudatta Bandgar
      This is a BUG 52096
      Hello DrkAngl
      This bug is highlighted before, and the developers are working on it. I will get an update if there is any.
      Regards.
Viewing 3 reply threads
