December 7, 2022 at 3:42 pm
aubnku
SubscriberHello, I have to simulate the rotation of a fluid inside this part which is rotating around the Z-axis with a 30mm radius.
The problem is that when i click on preview mesh motion my body is also rotating. (see picture attached)
My objective is to have a rotation of 30mm but with my body part which is keeping the same orientation.
Do you have any ideas to process this problem ?
Thanks a lot for your answers ! -
December 8, 2022 at 10:34 am
Ansys EmployeeCommon issue. You need to rotate two bodies so that the red one rotates relative to the body that’s following the green path. Have a look at some of the VAWT threads on here as it's a technique used in those models.
December 8, 2022 at 2:25 pm
C N
Ansys Employeehello
In addition to that
I recommend you to distinctly separate the fluid and the object under cell zones setting and create two zones.
Then create a profile for the object and then for the fluid with appropriate requirements.
Then apply the dynamic meshing option in which set the stationary motion option type to the object .
By default if no motion (moving or deforming) is assigned to boundary or cell zone, this zone is not considered during the mesh update. Then apply rigid body motion option to fluid about z axis orientation by loading that fluid profile.This may solve your problem and then the object will not rotate along with the fluid. You can also create a separate udf instead of creating profile. For further understanding please check on dynamic meshing tutorials from users guide. hope it may solve your problem.
thank you
December 16, 2022 at 1:58 pm
aubnku
SubscriberHello ! Thank you, I will try everything you told me and get back to you if I have any issue. I'm quite new to using UDF but I guess there are tutorials available
Thanks -
January 3, 2023 at 11:55 am
Ansys EmployeeThere are tutorials in the manual.
2630
2104
1329
1110
461
