February 2, 2022 at 8:10 am
s3740222
SubscriberHello,
While I am simulating Maxwell3D design with the Maxwell circuit, I am getting error "Error in reading external circuit file.95"
The circuit is imported successfully, but after starting the simulation run, the error appears as "Error in reading external circuit file.95".
Can someone help me in this regard?
February 2, 2022 at 3:00 pmDeyu Li
Ansys Employeecan you provide a screenshot of the MaxCir?
February 2, 2022 at 10:35 pmFebruary 2, 2022 at 10:39 pms3740222
Subscribercan you see the image please ?
February 3, 2022 at 12:22 amFebruary 3, 2022 at 12:23 ams3740222
SubscriberI tried to send the screenshot but do not know why it's not working.
February 7, 2022 at 2:19 pmDeyu Li
Ansys Employeeyes I can see the pictures, there is no source in the circuit.
August 8, 2022 at 7:33 ams3740222
SubscriberI am still not able to solve this.
Viewing 7 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
3670
2548
1749
1226
582
