March 11, 2022 at 12:41 pm
iceblink
SubscriberHow can we provide custom information to the cluster regarding "The license necessary to execute the job, which can be used to integrate with cluster resource management to check Ansys license availability before a job starts running" please?
(The Help states "For more information on how to integrate licensing with cluster software, contact your cluster administrator or Ansys customer support." which is not very helpful for a Help. )
March 22, 2022 at 2:07 pmMarch 22, 2022 at 3:01 pmiceblink
SubscriberIn that case, can you please tell me if there is a formula or lookup table where one can see how many licenses of each type are required for an analysis using a certain number of nodes and/or cores? Using Mechanical, so only focusing on prepost / solver / bundles / HPC licenses will suffice.
It needs to be possible in some way for the queueing system to check whether sufficient licenses are available before starting a job. We can see the number of available licenses, but we don't know how many are required for a certain run.
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2656
2120
1349
1118
461
