RSM Model
    • ashiadarsh
      Hi All,
        What is the desired Y+ value for RSM Model?
      Adarsh
      It depends on which near wall approach you're using: wall functions or resolving the viscous sub layer.  Read the User's and Theory Guides for wall treatment.
    • ashiadarsh
      Ok Thank You for the reply....Earlier Rahul Raghav has forwarded one article on this which was very useful..my understanding is that, if you want to resolve the viscous sub-layer,irrespective of which turbulence model you use(k-w SST,K-Epsilon or RSM) your Y+ should be below 5 or close to 1.Pls comment on that.
      Thanks,
      Adarsh
      Correct, but you also need to include suitable wall functions for RSM as the default is designed for  30 < y+ < 300  hence me advising you read up on the wall treatment.
Viewing 3 reply threads
