July 18, 2019 at 8:52 pm
heechangna
SubscriberDear,
We have a rsh wrapper (pbsrsh) on our cluster.
We like to use pbsrsh instead of ssh or rsh for RSM.
Are there any options to change it?
I found that there is an option of a check box for ssh or rsh from the RSM configuration application, but we need to use "pbsrsh" explicitly.
Thanks!
-Heechang
December 16, 2019 at 8:14 pm
heechangna
SubscriberI am wondering if I can get any support on this matter.
Thanks.
-Heechang
December 17, 2019 at 9:33 pm
George Karnos
Ansys EmployeeHello Heechang,
What solver type will you be using?(Fluent, Mechanical, etc.),
What version of the ANSYS Software version?
What Cluster type (PBS Pro or Torque with Moab)?
What Operating System?
Best, Geo
December 18, 2019 at 6:25 pm
heechangna
SubscriberHi Geo,
Thank you so much for the response!
I think this would give you more direct question.
So, From https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/rsm_tutr/rsmtut_custserv_setupclientmgr.html?q=rsh,
it says that rsh is the default and we can change to ssh by click on the check box.
But, we want to use our own rsh wrapper, called pbsrsh. Is this possible?
Anyway,
solver type: ensight.
Ansys version: 2019R1
Cluster type: Torque with Moab
OS: RHEL 7.6
Thank you so much!
-Heechang
December 19, 2019 at 6:45 pm
tsiriaks
Ansys EmployeeHi Heechang,
I'm not familiar with Ensight. Can you check out the ANSYS Knowledge Material (KM) # 2057599 from the customer portal, to see if it gives you any clue/direction ?
Thanks,
Win
December 19, 2019 at 7:15 pm
heechangna
SubscriberHi Win,
Thank you for this!
I tried to search "2057599" from the ansys customer portal, but the ID number is not searchable, I think.
I tried it from the Soulutions Search from the Knowledge Resources tab, but it is not working as well.
Can you please give me a link to the page?
Thanks again.
-Heechang
December 30, 2019 at 6:25 pm
heechangna
SubscriberHi Win,
Can you please give me a link or an instruction to get the information about ANSYS Knowledge Material (KM) # 2057599?
I tried many different ways, but I cannot get the information.
Thank you so much!
-Heechang
January 2, 2020 at 9:45 pm
tsiriaks
Ansys EmployeeSorry, I was on vacation.
Here is the info in that KM
Background information: Default remote launcher of distributed Mechanical APDL from master compute node to slave node(s) is ssh. The -usersh flag can be added to change to rsh which rarely used in modern Linux cluster. Refer below process tree on master compute node and a salve compute node of a PBS Pro job for distributed Mechanical APDL, Intel MPI processes on master compute node are launched under pbs_mom, but Intel MPI processes on slave node are launched from ssd which is not monitored and managed by PBS Pro (pbs_mom). It’s possible that sometimes killing PBS Pro job (e.g. through qdel jobid) only kill processes on master node, leaving zombie processes on slave node(s) which are launched by sshd rather than PBS Pro pbs_mom.
Solution:
-- Set below 2 environment variables:
export I_MPI_HYDRA_BOOTSTRAP=rsh
export I_MPI_HYDRA_BOOTSTRAP_EXEC=/opt/pbs/default/bin/pbs_tmrsh
-- Add -usersh in distributed MAPDL command line.
-- Backup and edit {installed_path}/ansys_inc/v193/ansys/bin/anssh.ini, go to line # 483, change this line from
${rshcmd} -n ${i} mkdir -p "'${dirpath}'"
to
/opt/pbs/default/bin/pbs_tmrsh -n ${i} mkdir -p "'${dirpath}'"
When a distributed Mechanical APDL job is launched by PBS Pro and runs on multiple compute nodes, MPI processes on both master node and slave node(s) will be launched by pbs_mom:
Now, you are using Ensight, so the second and third steps would definitely be different but could be in a similar manner (adding/modifying certain switch and certain file for Ensight to control its solver).
January 9, 2020 at 9:11 pm
heechangna
SubscriberHi Win,
Thank you so much for the information. This definitely gives us more information.
So, I figured that each component or/and solver in ANSYS, like fluent, ensight, etc, has independent setting rules for ssh/rsh.
We always want to use the rsh wrapper. If we don't use it, there will be strayed jobs. (This is mentioned on your previous message.)
And, it is very difficult to set, because each solver is different.
Even with the information you gave, I cannot make ensight with the wrapper. Is there any support on this?
And, we have the same issue on fluent as well. Can you please help?
For fluent, I have a command like
fluent 3ddp -t$ncpus -pinfiniband.ofed -cnf=pnodes -g < input_file
Then, in the output file, we can see that it use "ssh":
/usr/local/ansys/2019R1/v193/fluent/fluent19.3.0/bin/fluent -r19.3.0 3ddp -t40 -pinfiniband.ofed -cnf=pnodes -g
/usr/local/ansys/2019R1/v193/fluent/fluent19.3.0/cortex/lnamd64/cortex.19.3.0 -f fluent -g (fluent "3ddp -pinfiniband -host -r19.3.0 -t40 -mpi=ibmmpi -cnf=pnodes -path/usr/local/ansys/2019R1/v193/fluent -ssh")
/usr/local/ansys/2019R1/v193/fluent/fluent19.3.0/bin/fluent -r19.3.0 3ddp -pinfiniband -host -t40 -mpi=ibmmpi -cnf=pnodes -path/usr/local/ansys/2019R1/v193/fluent -ssh -cx o0314.ten.osc.edu:41251
6606
Starting /usr/local/ansys/2019R1/v193/fluent/fluent19.3.0/lnamd64/3ddp_host/fluent.19.3.0 host -cx o0314.ten.osc.edu:41251
6606 "(list (rpsetvar (QUOTE parallel/function) "fluent 3ddp -flux -node -r19.3.0 -t40 -pinfiniband -mpi=ibmmpi -cnf=pnodes -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "40") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/usr/local/ansys/2019R1/v193/fluent") (rpsetvar (QUOTE parallel/hostsfile) "pnodes") )"
I tried to put "-rsh", "-usersh" and setting the environment variables, but no luck so far.
I tried to read through the manual, but there is not so much of information about it.
Any comments or information would be very helpful.
Thanks.
-Heechang
January 10, 2020 at 8:51 pm
tsiriaks
Ansys EmployeeHeechang,
There might be a way for Ensight to use rsh but it can't be used with RSM. Please refer to this guide
Similarly for Fluent, you can't use it with RSM but you can try adding a switch in the submission command, see
Thanks,
Win
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3862
2629
1859
1252
600
