May 11, 2023 at 10:57 pm
Fady Elshazly
SubscriberHello,
I am trying to model rubber layer in lsdyna. it supports a cyliner overlying it. I find error termination in the dynamic relaxation phase showing rubber negative volume and severe distortion for the layer.
What is the way to prevent negative volume and the best material to model the rubber layer?
Thanks
May 12, 2023 at 12:48 pm
Ram Gopisetti
Ansys EmployeeHi Fady, you can check the following link for fixing the negtive volume issue in rubbers or any soft material
https://www.dynasupport.com/howtos/material/negative-volume-in-soft-materials
cheers, ram
May 13, 2023 at 11:45 pm
Fady Elshazly
SubscriberI have tried all of theses steps and still getting the error termination in the dynamic relaxation phase. Can this happen because the rubber is supporting a very high weight? and if so what would be the solution.
Thanks
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5268
3299
2469
