Run a log file from APDL using aas MATLAB
    • JTWD
      Hello everyone !
      I'm trying to go a genetic algorithm is MATLAB for a buckling case in ANSYS APDL.
      I download aaS toolbox and installed it inside MATLAB, no problem. I make it run also ans still no problem.
      My problem is that I can't run my APDL commands file inside MATLAB. My only way is to use the command ' char(iCoMapdlUnit.executeCommandToString('/prep 7'))' for each line !
      But my file is a bit long, and do many things (many loops, write stuff in different excel files and do buckling analysis) that can't be done with a command prompt. In APDL the only way is to import my txt file inside my project.
      If you have any ideas of how to fix mu problem it will be great ! Thanks in advance !
    • Aniket
      Unfortunately this question is beyond the scope for ANSYS employees to answer on a public forum, so hopefully, other student community users can chime in.
      -Aniket
    • JTWD
      You means, I will have more chance in the Ansys Customer Portal ?
    • Aniket
      I think yes, if you have an account on the customer portal.
    • JTWD
      Hello, I searched with my customer account and the only resource available was the one from the student community.
    • Aniket
      Really sorry then, I hope that other members who are not ANSYS employees can help in this case.
    • AhmedHeello
      Hello, i have a problem that i want to solve,  i want to run ANSYS MECHANICAL APDL by using Matlab.  the easiest way that i can do this issue can you help me.
      thanks
    • JTWD
      Hello !
      I found 2 solutions. Either you run your ANSYS code as macro code directly inside ANSYS (but didn't work for my code) or if you have a professional licence you can use the add on aaS. But the last solution is so so because nobody can help you to do your stuff and the ANSYS documentation is very poor.
Viewing 7 reply threads
