November 11, 2020 at 8:42 pm
mehrdadsaeedi
SubscriberHello friends,nI am trying to run a simulation in which I have to apply approximately 700 load steps on several nodes and export the corresponding x,y,z displacements for each node and for each set.nfor example I have a node that there will be loads applied on. for this node I have considered 720 load steps which each gives specific displacements. the question here is how can I export the corresponding directional displacements for all those 720 sets at one time? I thought that this could be done by using a for loop or something similar.nThe problem is I have little knowledge of APDL commands.nI appreciate any help.n -
November 11, 2020 at 10:22 pm
Wenlong
Ansys EmployeeThis is a rushed answer and others please feel free to add comments.nHi mehrdadsaeedi,nYes a do loop can help. In Mechanical, right click on solutions and choose commands to insert a command snippet. Say you want to plot displacements at all these steps, you can add:n*do, i, 1, 720n/show, PNG, REV,,8, ux_at_step_%i% !output a PNG imagen/post1nset, i, lastnallsel, allnplnsol, u, x !plot x displacementn/show, close n*enddonnIf you want to print out the solution, you can use command like prnsol. I am sure there are better options to directly write to a file. Others feel free to contribute. nRegards,nWenlongnReference: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/ans_cmd/Hlp_C_DO.html?q=\*donhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_cmd/Hlp_C_PRNSOL.html?q=prnsoln -
November 13, 2020 at 4:57 pm
HarsihilZLHZ
Subscriber/POST1nset,lastn*get, numnode, node, 0, countn*DIM,DN,array,numnode,3n*do, j, 1, numnoden *get,dispX,node,j,u,xn *get,dispY,node,j,u,yn DN(j,1) = j t t n DN(j,2) = dispXtn DN(j,3) = dispYn*enddonn*CFOPEN,file_Name,txt,Z:\Ansys(here comes directory)n*vwrite, DN(1,1),DN(1,2),DN(1,3)n(4x,' ', F6.0,4x,' ',G15.8,4x,' ',G15.n*CFCLOSEnnif it doesn't worked, then share your file if possible.n -
November 13, 2020 at 10:26 pm
mehrdadsaeedi
SubscriberThank you HarsihilZLHZ for your reply. the file is not something special. it is just a simply cube with hexahedral elements and 1 node receives a nodal force with tabular data for a certain load step. I tried your code but it only produced a blank text file. Here is my file attached.nn
November 15, 2020 at 2:05 pm
HarsihilZLHZ
Subscriberfor the time being consider below code...n!!! I HAVE TESTED AND IT WORKSnn*DO, i, 4, 5 ! here I have used last two subset (edit here!!) (!!!! ATTENTION here i have used 4 and 5 SUBSET)nSET, i,LASTnnn*GET, my_numnode, node, 0, countn*DIM,DN,ARRAY,my_numnode,4nn*DO, j,1,my_numnoden *GET,my_dispX,NODE,j,U,Xn *GET,my_dispY,NODE,j,U,Yn *GET,my_dispZ,NODE,j,U,Zn DN(j,1) = j n DN(j,2) = my_dispXn DN(j,3) = my_dispYn DN(j,4) = my_dispZn*ENDDOnn*IF,i,EQ,4,THEN !!!! ATTENTION here i have used 4 and 5 SUBSETn*CFOPEN,fileName1,txt,\ !!!!(writes the file for 1 subset)n*vwrite,DN(1,1),DN(1,2),DN(1,3),DN(1,4)n(4x, ', F6.0,4x, ',G15.8,4x, ',G15.8,4x, ',G15.n*CFCLOSn*ELSE !!! ( if you have more than two subset then write *ELSEIF,VAL1,Oper,VAL2 )n*CFOPEN,fileName2,txt,\ !!!!(writes the file for 2 subset and so on.....)n*vwrite,DN(1,1),DN(1,2),DN(1,3),DN(1,4)n(4x, ', F6.0,4x, ',G15.8,4x, ',G15.8,4x, ',G15.
n*CFCLOSn*ENDIF nn*ENDDOnn
- The topic ‘Run a simulation for a large number of load steps and export all sets displacements at once’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1480
