July 11, 2020 at 11:39 am
KevinG
SubscriberHello,
I want to run Ansys with SMP. From the product launcher, this can easily be done from the High Performance Computing Setup tab. However, when I call ansys in batch mode from an external file, it runs using Distributed Computing. So my question is, how I use SMP when calling ansys in batch mode without using the product launcher?
Thanks
July 11, 2020 at 2:15 pm
KevinG
SubscriberFound the solution. I manually changed to shared-memory parallel when calling Ansys by using '-smp -np2' in my call command. This link was very helpful; https://www.padtinc.com/blog/starting-ansys-products-from-the-command-line/
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
- ANSYS 19.1: Can not link the geometry
- 19.1 FREE Student Products are Released
- SpaceClaim – The geometry editor was closed abnormally.
- Missing Analysis Systems tab from toolbox in Ansys workbench 19.2
- Error downloading 18.1 or 18.2 student
- The Fluent Application Failed to Start.
- 19.1 – Error message when opening Workbench
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
