April 9, 2018 at 4:53 am
rrdbes
SubscriberAnyone here experienced this kind of error during run calculation? Might thinking this could be a hardware issue. Any thoughts? Thanks!
April 9, 2018 at 9:16 am
Ido Yudhatama
SubscriberI see you opened too many programs in your taskbar, try to close it make your calculation run faster. First, check your minimal system requirements for ANSYSÂ in here. Then if you have done with that, also observe your CPU and Memory performance in task manager in order to check which part is needed to upgrade.
Good luck
April 9, 2018 at 9:31 pm
April 15, 2018 at 11:52 am
Raef.Kobeissi
SubscriberMake sure to wait until Fluent fully loads all your data as displayed in the console, don't press or switch windows until the loading is complete otherwise you might receive this non-responding error due to processing overload.
- The topic ‘Run Calculation Error’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
