August 21, 2019 at 9:46 pm
guimilan
SubscriberHi everyone,
I'm having issue running ANSYS Mechanical on multiple cores. I'm running on a cluster (operating system: linux) and I have no access to the graphic interface of ANSYS. I have tried to use the -np #cores (and the -dis -np #cores) command in the terminal, but I get the error "-bash, command not found".
Is there any command line to type in the terminal that does the same as Tool > Solver Settings > Advanced > ... in Mechanical app?
Thanks for helping.
August 22, 2019 at 2:48 pm
Sandeep Medikonda
Ansys EmployeeCan you provide a snapshot of the problems you are experiencing?
- Changing of font size
- System Coupling
- ANSYS Workbench Mechanical Solver problem after saving
- 3D ROM in workbench
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- ANSYS Direct Optimization
- HARDWARE COMPATIBILITY
- System Coupling
- When I open the Electronic Desktop, Twin Builder auto opens
2564
2080
1299
1106
459
