run simulations in sequence????? [ansys maxwell]
    • carolinat4
      there is any way that i could run simulation in sequence? i have 9 files to run, each one takes about 1 hour to finish, i would like to know if there is a way to set up those simulations in sequence. i don't want to run all of them together because probably my pc will crash. i'm using ansys maxwell. thank you.n
    • Navya C
      Hi,nTo run the simulations in sequence you can you use queue simulations settings as shown below.nnnRegardsnNavyan
