August 30, 2023 at 6:58 pm
Ashwini Kumar
Ansys EmployeeFor optimum performance of Ansys Fluent 2023 R1 on hpc6a/hpc7a instances running on Windows, we recommend the following settings in the launcher:
- Change the MPI to msmpi from the default
and
2. Type FLUENT_AFFINITY=0 [zero] in Environment tab
These settings will be set by default in Ansys Fluent 2023 R2.
In the CFD Pro licenses, the environment tab is disabled. Launch Fluent using the command prompt:
> "C:\Program Files\ANSYS Inc\v231\fluent\ntbin\win64\fluent" -affinity=off
when launcher opens, set the desired core count and continue:
One can modify the shortcut that launches Fluent as follows
September 6, 2023 at 3:04 am
Mason Morris
SubscriberI have installed it and feel the performance is more optimal than before.
- (0x8007052E): The user name or password is incorrect
- Some of the instance types are greyed out and cannot be selected.
- Ansys Gateway powered by AWS – Minimum Technical Skills
- ADConnector Installation Fails due to .NET
- Welcome to Ansys Gateway powered by AWS
- Unable to install Service.
- About Multi-domain support
- Ansys Gateway powered by AWS – Express Setup Overview and Prerequisites
- What is the average time to set an HPC cluster up?
- How does metering work?
7742
4502
2963
1449
1322
