Running APDL in batch mode
    • helen.durand
      Hello ANSYS forums,
      I want to run a Workbench thermal / structural simulation without the user interface on a Linux-based HPC system.
      Can I use the database (ds.dat) from the Workbench project_files folder and use the process outlined in section 4.4 in the Operations Guide (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_ope/Hlp_G_OPE3_4.html)?
      I assume I want to enter a command something like the following:
    • Ashish Khemka
      Hi,nnYou can rename the ds.dat file as .inp file and use the same as an input for batch run. For the command indicated refer the point#14 in link below:nnnRegards,nAshish Khemkan
