Ansys Products
Ansys Products
Running first-time configuration, everytime
    • ahkumar
      Dear Ansys support,
      We have Ansys 19.1 installed on our cluster and every time I run ansysedt "first-time configuration" is rerun. A user could get a random compute node for their runs. Given the installation is on a shared folder and users home directory are same across the cluster we get the attached error.
      Can you please help resolving this issue. How can I suppress this first time configuration for a user if he/she has already run and initialized on another node?
      Please let me know if you need additional information.
      Best Regard,
      Amit
    • ANSYS_MMadore
      Hello Amit,
      You can set this variable to avoid the check.  ANS_NODEPCHECK=1
      Thank you,
      Matt
    • ahkumar
      Thank you!! That did it.
    • ahkumar
      Although it does not tell me why it keeps re-running the first-time configuration. If there is a fix for that then I don't have to instruct users to use this variable.
      Would love to hear if there is another implicit solution.
      Best Regards,
      Amit
    • tsiriaks
      Hi Amit,
      Can you set the environment variable ANS_NODEPCHECK=1 in the bash profile file for all users , so it gets set each time they login ?
      Thanks,
      Win
Viewing 4 reply threads
