Running Fluent on Cluster- clear Node Cache
    • soloviev
      I am running models on a HPC cluster (Linux). I received the following warning.
      WARNING: Rank:44 Machine node002 has 13 % of RAM filled with file buffer caches.
      This can cause potential performance issues. Please use -cflush flag to flush the cache.
      (In case of any trouble with that, try the TUI/Scheme command '(flush-cache)'.)
      I tried using -cflush on the node of the HPC and it says its an invalid command. I also tried 'flush-cache' in the Fluent console and it also said it is an invalid command. Where is the proper place to use this command?
      Thanks,
      Alex
    • BiomedModeller
      I have a similar problem as welln
    • soloviev
      Hi BiomedMOdeller,nnI found the command n# sync; echo 1 > /proc/sys/vm/drop_caches nnworked for me!nThanks,nAlexn
