August 21, 2018 at 8:07 am
software1
SubscriberFor mechanical analysis there is a batch mode but I can't find it for fluid analysis. Is it normal?
According to another topic "How to use the remote submit by solver mode "batch" in AIM?", it seems that RSM is not compatible with AIM. In this case, how to manage my cpu to avoid to run Mechanical and AIM analysis on the same CPU?
August 21, 2018 at 11:13 am
Gaurav Sharma
SubscriberHi JD
Batch Mode can be opted with both ANSYS Mechanical and ANSYS Fluent. In case you are facing any issues with these, I suggest you to please use ANSYS Customer portal to raise a separate query.
While Batch mode is also supported in AIM, remote solving on clusters is not supported as of now. Batch mode can be opted by going to “Launch Controls” under “Physics tab in AIM as shown below:
Regarding the conflict, there is no available option at the level of program settings to control this and in case both Mechanical and AIM are running on your machine, they may run on different cores or share the same depending on number of available cores. This may have an impact on the runtime of your solutions but isn’t expected to have any other adverse effect.
However beyond ANSYS or Discovery Settings, the generic options available with Windows task manager can be helpful in having some control on the CPU usage. You can “Set Priority” or use “Process affinity” to govern which cores are to be used for which task in case you like to.
Please let me know if you are facing any specific problem running both AIM and Mechanical.
Thanks & Regards,
Gaurav
August 5, 2019 at 7:51 am
mariarita De Rinaldis
SubscriberHi Gaurav_ANSYS !
In the 2019 r2 i can't find the same panel for launch controls... How can I run in batch mode?
August 5, 2019 at 9:39 am
Gaurav Sharma
Subscribermariarita
I can see that the option is no longer there. Let me check with the team and I will get back to you soon on this.
Gaurav
August 6, 2019 at 11:43 am
Gaurav Sharma
Subscribermariarita
I have learnt that the default "Solver mode" behavior in AIM is switched to "Batch" and the "Live" solver option is now removed. This was done for both, performance and to remove some defects associated with the "Live" solver mode.
Gaurav
August 6, 2019 at 1:30 pm
SubscriberGaurav_ANSYS thank you very much
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
- Unexpected graphics error
5364
3363
2471
1310
1018
