Running Windows models on Linux
    • AliNabizadeh
      Hi everyone,nnI want to create my Ansys Fluent models on Windows and run those files on Linux without going through the same set-up procedure. How can I run Ansys on Linux without opening the software? nnI can create a journal file on Windows, but I do not know how to run it on Linux.n
    • Anita2020
      Hello,nPlease go through this link: https://www.padtinc.com/blog/starting-ansys-products-from-the-command-line/nI think this link will help you to know more about running Ansys on Linux.nnThanks,nAnita.nn
      Thanks, I'll delete the other 5 posts that look to have been generated, if a post doesn't arrive please be patient. nI'll move this to Fluids as it's not Platform in the Ansys sense of the term. nThe link will highlight the command line options in Fluent, they're also covered in the documentation. There's also a section on running in the background on Linux, check with the cluster admin in case there's anything you need to be aware of. You will also want to read up on TUI scripts. n
