May 13, 2022 at 3:05 pm
Adhistira
SubscriberHi,
Currently I am following the Getting Started with Maxwell: A 2D Magnetostatic Solenoid Problem. I have done the nominal simulation and it runs with no issue. But when I start the parametric simulation, it gives me "Same vertex for the begin and end of the face" error message. Before that message, it gives me "Failed to extract solution" and "Failed to evaluate calculation" at every step of the sweep.
I hope someone can help me with this, as I followed the instruction from the Getting Started with Maxwell: A 2D Magnetostatic Solenoid Problem module from ANSYS itself.
Thank you!
July 18, 2022 at 10:57 amAnchal Singh
Ansys EmployeeHello Adhistira,
Can you please mention the workshop name and number, you are trying to follow?
Anchal
Ansys
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8786
4658
3151
1678
1468
