Sand Mixing
    • shrav007
      I'm trying to model sand mixing with a resin. I'm using Eulerian Multi phase model. The mixing is solid-liquid mixing. In material properties, for sand, how should (or what value) I give the viscosity to sand ?n
      Check the manual, but it shouldn't matter as the granular viscosity will take over: do NOT set it as zero! n
    • shrav007
      Thanks for your answern
