LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Sandstone temperature problem
    • javat33489
      Hi all.
      I'm simulating drilling into a sandstone SPG ram.
      Drill - MAT_PLASTIC_KINEMATIC, sandstone - MOHR_COULUMB.
      The units I use are: GPa, ms, kg, mm.
      I use explicit analysis and the following settings:
      I indicated the initial temperature in Celsius 22 degrees, is this correct or should it be indicated in Kelvin?
      ___
      I waited for two entries in the d3plot and saw that the temperature on the SPG particle plate was very high, why?
      Temperature graph on an SPG slab:
      And how can this be fixed? Maybe you need thermal expansion cards?
    • Ram Gopisetti
      Hi
      Can you let us know the solver used ?
      Cheers.
      • javat33489
        I use explicit analysis.
        Version of the solver from the Ansys 2023 R1 package.
      • javat33489
        Guys, I carried out an analysis when the drill passed through the SPG die and this is what happened:
        The temperature at the SPG slag is very high. Why? How to deal with this?
      • javat33489
        Help please
      • javat33489
        I need help
