July 31, 2020 at 6:14 pm
VivekKamble
Ansys EmployeeWhat is saturation and why and how does an electrical machine saturate?
Charlotte Blair
Ansys EmployeeWhen we say saturation in electrical machines we are speaking about magnetic saturation. If we increase the mmf of the magnet or if we increase the current in the coil, the flux density inside the iron of the machine is also increased. There is a limit beyond which magnetic flux density in the core will not increase proportional to the mmf. This limit is called magnetic saturation.
rtk
Ansys EmployeeHello,
How does it affect the electrical machine?
July 31, 2020 at 6:15 pm
Charlotte Blair
Ansys EmployeeHi @cblair,
When magnetic saturation sets in, the machine performance will not increase much even the magnetomotive force (MMF) is increased. You can understand these limits of the steel used in the machine by looking at the BH-curve of the steel. The knee point where the curve starts becoming parallel to X axis (H) is where the steel starts saturating
A saturated core requires more magnetizing current. This will increase I2R loss in the winding thus overheating the machine.
March 19, 2021 at 5:03 am
isaichaitanya
Subscriberhow to test magnetic saturation effect in pmsm using ansysnn -
June 30, 2022 at 3:45 am
kunaldugvekar
SubscriberYou can check magnetic flux densities & compare it with used material
s saturation levels. Also for a machine, a simple OCC test & voltage
s non-linearity can indicate saturation in the machine.
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- How to calculate the Lorentz Force, Damping Force and Damping coefficient in 3D transient Analysis
- How to decide “time at the end of load step” for a transient analysis.?
- Return loss and Reflection Coefficient
- Difference between directivity and gain
- Maxwell: variables in material definition
- Designing an electromagnet simulation to calculate the magnetic flux density.
- * Error* there is at least 1 small equation solver pivot term (eg. VOLT DOF of node 575)
- Cogging torque
- B-H Curve Interpolation
- EIRP
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
