Sauter mean diameter
    • prashant
      How to plot sauter mean diameter with respect to distance
    • DrAmine
      Which software you are using? Which distance? Can you add more details so that we are able to reply.
    • prashant
      I am using fluent, I have made a cylindrical geometry with pressure swirl injection in the axial direction at the top surface. so I want to calculate SMD at different locations of the domain.
      Is it a steady or transient DPM calculation?
    • prashant
      It is a transient simulation,although i want to lean for cases
      The particle size can be plotted on the DPM tracks. If you create a surface you can also run a DPM Summary: I think you can calculate the Sauter mean diameter from that output file.
    • DrAmine
      check Summary Reporting of Current Particles in the User's Guide for definitions!
    • prashant
      Actually I have made a cylindrical geometry I want to create surface of specified dimensions, but I am unable to make it. Next I want to extract particle summary in that particular domain.
      I have already extracted Particle summary through console window but it is providing data for whole domain.
      So overall I need value of SMD particular domain.
      Your response is solicited. Thanks for helping me.
      Then you need to create planes or fluid regions to report on. Have a look at surface creation and see if that does what you need.
Viewing 8 reply threads
