September 12, 2021 at 9:30 am
DemingMeng
SubscriberI met a very strange error when I want to save data. After running the simulation, when I want to save the data, if I save the picture into the folder of the programme (or the master/son of the this folder), after saving, nothing will show in the folder. However, I can save the data into the desktop or other folder. Why this happened?
September 15, 2021 at 6:23 pmLito Yap
Ansys EmployeePlease copy and paste the screenshot/image into post. Otherwise, try to save any file or data into your "user" folder since the "Program files" folder will require admin access. i.e. your Desktop, Documents or Downloads folder.
Best Lito
September 15, 2021 at 8:19 pmSeptember 15, 2021 at 9:25 pmSeptember 15, 2021 at 10:31 pmSeptember 15, 2021 at 10:59 pmDemingMeng
SubscriberOk, I solved this. It sees that it is related with my folder contains some chinese characteristic. Thanks a lot!
September 15, 2021 at 11:59 pmLito Yap
Ansys EmployeeYou are welcome. Glad to to hear this.
Best Lito
Viewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Crash with Exit code 1073741819
- older version
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- What are the OpenGL drivers supported by SCADE Display KCG?
- What are the target language supported by the SCADE code generators?
- FLUENT APPLICATIION ERROR
- save data error
2630
2104
1327
1110
461
