LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Save Nodal Forces
    • Joey Richardson
      I am trying to save the nodal forces of a DYNA simulation and can't get the NODFOR file to generate. My card deck is below. Does anyone know what is going on here? Thanks!
      $ LS-DYNA Keyword file created by fem.dyna Python functions
      $ Created on 05:53PM on July 24, 2023
      *KEYWORD
      *CONTROL_ENERGY
      $ hgen, rwen, slnten, rylen
      2,2,2,2
      *CONTROL_MPP_IO_NOFULL
      *CONTROL_TERMINATION
      $ endtim, endcyc, dtmin, endeng, endmas
      0.0045,0,0.0,0.0,0.0
      *CONTROL_TIMESTEP
      $ dtinit, tssfac, isdo, tslimt, dt2ms, lctm, erode, ms1st
      1e-06,0.02,0,0.0,0.0,1,0,0
      *DATABASE_NODOUT
      $ dt, binary, lcur, ioopt, option1, option2
      2e-05,0,0,1,0.0,0
      *DATABASE_NODFOR
      1e-06,0,0,1,0.0,0
      *DATABASE_EXTENT_BINARY
      $ neiph, neips, maxint, strflg, sigflg, epsflg, rltflg, engflg
      0,0,3,0,2,2,2,1
      $ cmpflg, ieverp, beamip, dcomp, shge, stssz, n3thdt, ialemat
      0,0,0,4,1,1,2,0
      *DATABASE_FORMAT
      $ iform, ibinary
      0,1
      *DATABASE_HISTORY_NODE_SET
      $ id1, id2, id3, id4, id5, id6, id7, id8
      1,0,0,0,0,0,0,0
      *SET_NODE_GENERAL
      1
      ALL
      *PART
      $ Title
      background
      $ pid, secid, mid, eosid, hgid, grav, adpopt, tmid
      1,1,1,0,0,0,0,0
      *SECTION_SOLID
      $ secid, elform, aet
      1,2,0
      *PART
      $ Title
      background pml
      2,2,2,0,0,0,0,0
      *SECTION_SOLID
      2,2,0
      *INCLUDE
      ../../nodes.dyn
      *INCLUDE
      ../../elems.dyn
      *INCLUDE
      ../NodalLoads.dyn
      *INCLUDE
      Materials.dyn
      *INCLUDE
      LoadCurves.dyn
      *END
    • Ushnish Basu
      You have to use DATABASE_NODAL_FORCE_GROUP
    • Joey Richardson
      I tried adding this card:
      *DATABASE_NODAL_FORCE_GROUP
      1,1
      And got the following error:
       *** Error 10146 (KEY+146)
           coordinate set id 1 is undefined
           CHECKING NODAL FORCE GROUPS
      Do I need to setup some sort of coordinate set to be able to save forces? I don't think this has been necessary to save nodal displacements. Is there an example to see how to set this up/how to save forces?
    • Ushnish Basu
      If you don't have a coordinate system ID, then no need to specify one in that card, just specify the node set
    • Joey Richardson
      That worked! Thank you
      • Joey Richardson
        Spoke too soon... The nodfor file was created, but it is empty.
        Here is how I am creating my database and node sets. Do you have any suggestions on why the nodfor file would be empty?
        *DATABASE_NODOUT
        2e-05,0,0,1,0.0,0
        *DATABASE_NODFOR
        1e-06,0,0,1,0.0,0
        1
        0,0,3,0,2,2,2,1
        0,0,0,4,1,1,2,0
        *DATABASE_FORMAT
        $ iform, ibinary
        0,1
        1,0,0,0,0,0,0,0
        *SET_NODE_GENERAL
        1
        ALL
    • Ushnish Basu
      Unfortunately, we cannot comment on any specific case in this forum
    • Joey Richardson
      Is there any contact or support package for help with specific cases?
    • Ushnish Basu
      You can get in touch with your Ansys contact (likely the account manager) and ask them if you can be provided more personalised help.
      Ushnish
Viewing 7 reply threads
