November 26, 2019 at 8:21 pm
wolfgang.geist
SubscriberHi,
I try to save an ANSYS Discovery SpaceClaim 2019R3 file which was imported as STEP-file which was originally generated by SolidWorks both as STEP again or as Parasolid-file.
I received following message both for STEP but also Parasolid-save operation.
What´s wrong with it?
Thanks and regards
Wolfgang Geist
ConWeb GmbH
SpaceClaim-reseller in Germany
November 27, 2019 at 6:16 am
Subashni Ravichandran
Ansys EmployeeHello Ghost1246
Could you please make sure that you have sufficient space in the location where you would like to save the file? Could you also confirm that you have read-write permissions to the location where you are trying to save the file?
Could you try changing the file path for saving?If the error persists, please share the log file created in the below path.
C:Users
AppDataRoamingSpaceClaim -
November 27, 2019 at 8:05 am
wolfgang.geist
SubscriberSubashni
November 27, 2019 at 8:08 am
wolfgang.geist
SubscriberHello Subashni, there is no problem with the writing rights. I had a discussion with a SWX-expert and he told me that the problem starts with the way the SWX-user export things. There are a lot of potential errors and it is just not a flat conversion and import. Even our SWX-expert had problems to export the imported file. We have to ask the sender to try another SWX-export format - not STEP but the native format, etc. I will send the log file later.
Regards
Wolfgang
November 27, 2019 at 8:46 am
Thank you for that update. Please feel free to let us know if any further help is needed with regard to SpaceClaim.
November 27, 2019 at 10:24 pm
wolfgang.geist
we could solve the problem with the help of a combined SolidWorks/SpaceClaim partner. He found a lot of topological and geometrical problems in the STEP-file generated via SolidWorks. By fixing these errors, e.g. reorganisation of the parts provided in the STEP-file we could import the STEP-file in SpaceClaim at the end.
So it was a kind of corrupt geometry data and not an IT-issue and rights issue. The assembly is about 300 MB.
Thanks for your help.
Regards
Wolfgang Geist
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Discovery AIM Mesh Error
- Natural frequencies limited to first 6 modes
3744
2573
1821
1236
596
