May 11, 2022 at 11:34 am
fatemeh.hosseini
SubscriberHello every body.
I am working on CFD-DEM by coupling Fluent and EDEM.
This is a time consuming simulation that takes 2-3 weeks time. 3 time the workstation has been rebooted and all of my data disappeared.
I want to ask you, is there any way that I can save data until the interruption and continue the simulation when I turn the system On?
Thanks
May 11, 2022 at 3:24 pmRob
Forum ModeratorAuto-save is available in Fluent, I assume EDEM has a similar feature.
Viewing 1 reply thread- The topic ‘Saving Data’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
