Discovery Import
Discovery Import
Saving Results For All/Some Time Instances
    • sina
      I am doing an internal flow analysis in ANSYS Discovery. I know it is possible to save the "end time" results (for example flow velocity) as CSV file if use the "Parameter Study" window. But, is there a way to save/export the numerical values of the variables for all the time instances/steps? For example, save the velocity-time results for all time steps (or at least some of them) from the attached plot?
      ANSYS Discovery has the data to generate these prob results. But, I don't know how to access and save them.
    • Subashni Ravichandran
      Hello  Sina Amini Niaki
      Are you using Discovery Live or Discovery?
      It looks like you are using Discovery Live. Let me check if this is possible and get back to you.
    • sina
      Hi Subashni, it is Discover Live. Thanks
      The Chart will export all the values as a .csv format. To do this you can right-click the graph and click export. (see image)
      You can export the graph manually for every parametric study manually.
      • sina
        Thank you Subashni
        Is it added in newer versions?
      2020 R2 was the last version of Discovery Live.
      From 2021 R1 we have a new product called Ansys Discovery. In the new Discovery too, you have an option to export chart data.
Viewing 4 reply threads
