September 6, 2018 at 12:38 pm
ahmedetman
Subscriberhow can i create twisted blade of savonius wind turbine by using ansys?
September 6, 2018 at 12:47 pm
Keyur Kanade
Ansys EmployeeYou can use Skin/Loft option in DM or Blend/Pull option in SpaceClaim.
Keyur
September 6, 2018 at 4:11 pm
ahmedetman
Subscriberthanks
September 14, 2018 at 4:37 pm
ahmedetman
Subscriberthe problem has been solved
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2614
2092
1321
1108
459
