3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
SC 2023 R1
    • design
      Recently updated to Spaceclaim 2023 R1.
      When using ‘Pull’ or ‘Move’ the ‘Measure’ option does not work when selected from the mini-toolbar. The option appears but does not function.
      It does work when selected from the main options panel.
      Is this some kind of configuration issue, or a bug?
    • Atharv Joshi
      Forum Moderator
      Hi SAC ,
      Can you please share a short video on the problem you are facing?
      Thanks and Regards
    • design
      Sorry, I do not have video capability.
      However I got the terminology wrong on my original post. The issue is the 'Ruler' option, not 'Measure'.
      With the 'Pull' or 'Move' tool active, pick a surface. The mini toolbar pops up; pick the 'Ruler' option. No ruler appears. Pick 'Ruler' option from the main option panel and it works normally.
      Sorry for the confusion and thanks for the response.
    • Atharv Joshi
      Forum Moderator
      Hi SAC ,
      I am unable to reproduce the problem. Ruler should appear after you move the cursor to fix the other end of the ruler. Please see the attached video.
      Thanks and Regards
      🛈This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions
Viewing 3 reply threads
