May 4, 2021 at 11:16 pm
Higgsco
SubscriberSo I got an full license for ANSYS SCADE from my university, and I wanted to make an example as it is shown in tutorial video from official Ansys Youtube channel (https://www.youtube.com/watch?v=cUw7uY_Hz7Y). I think I made all the steps correctly and when I want to generate FMU file I got an error :
*** FMI generation Error (CODEGEN): Unable to extract FMI data from mapping file
*** FMI generation Error (CODEGEN): Periodicity not defined in the Properties of the selected root operator or defined with incorrect overiding values in code generation Settings. Please specify values as appropriate.
Do you know what is the problem here? I need to find solution ASAP, please, help me!
May 10, 2021 at 1:19 pmKR
AdministratorHello When we build a FMU, since we have integrators/derivators, we must specify the periodicity of the controller. You have several options:
Set the periodicity in the root operator's properties, tab 'Code Integration':
Set the periodicity in the 'Code Generator's Settings':
Tab Code Integration:
I hope this helps.
Karthik
May 17, 2021 at 9:08 pmHiggsco
SubscriberThank you, it worked well. But I think there really should be some more tutorials for SCADE, specially for students.
June 22, 2021 at 9:30 pmKR
AdministratorExcellent!
Karthik
Trending discussions- What are the OpenGL drivers supported by SCADE Display KCG?
- What are the target supported to integrate SCADE Suite generated code?
- How to get event from Arinc
- What are the OS supported by SCADE products for installation?
- How does Medini calculate FITs based on mission profile?
- Command or tool to extract information about input and output data associated to a specific node
- SCADE – FMU file
- ANSYS SCADE: The map iterator explained
- Integrating C Code generated by KCG in Software Application
- What is the most efficient way of implementing a FOR LOOP in SCADE Suite
8798
4658
3151
1680
1470
