January 12, 2023 at 11:52 am
ehsan.sadeghi
SubscriberI am little bit confused with the source term definition in my UDF. My question is if I should devide potential_source by cell volume or not? I have read in some posts here that it should be devided by cell volume and in manual there is no mention of such devision.
DEFINE_SOURCE(S_potential,c,t,dS,eqn)
real potential_source;
dS[eqn] = 0.0;
potential_source = (C_UDSI(c,t,1)*E_E)/EPS_0;
C_UDMI(c,t,4) = potential_source;
return potential_source;
January 12, 2023 at 12:57 pm
DrAmine
Ansys EmployeeWhatever you return back in Ansys Fluent should be per cell volume. Example for continuity the Source term dimension should be in kg/s/m³. As in the UDF everything is "dimensionsless" you should take care about the right dimensions and magnitude.
January 13, 2023 at 5:14 pm
ehsan.sadeghi
SubscriberThanks @DrAmine for your response. I have another question regarding MHD module. In my source terms I need access to potential gradiants. What macro should I use? I couldn´t find anything related to MHD macros in manual.
January 16, 2023 at 7:38 am
DrAmine
Ansys EmployeeI think that part is not documented and I cannot share any information on the non documented macros. If you have access to the customer portal you might find some knoweledge material showing to access potential variable and its gradient.
2524
2066
1279
1096
457
