Preprocessing
Preprocessing
Scale factor in Spaceclaim: what’s wrong?
    • jordimarce
      I have a surface lying in a plane with a squared geometry that have a side (let's say) 10 mm and I use the dyanmic scaling : http://help.spaceclaim.com/2015.0.0/en/Content/Scaling_solids_and_surfaces.htm If I write down a scale factor of 2 I do not understand why then the length of the side is always something different than 20 mm
    • Keyur Kanade
      Please select correct point
      Please go through help manual for more details
      Pulling (ansys.com)
      Regards Keyur
    • jordimarce
      Well, I was selecting the right point. I finally saw what was going on. You cannot use the dynamic scaling with first moving the mouse to "activate" the scaling and then changing the value of the scale. Which I was understanding that it was the way to set the scale . You must change the value of the scale with space at the beginning of the operation of scaling alone.
