May 7, 2019 at 7:18 am
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHi, when you save a table setting on an output scale of 1: 1 spaceclaim does not save me this way but keeps the scale of the sheet 1: 2 or the one that is set
May 7, 2019 at 9:46 am
Subashni Ravichandran
Ansys EmployeeHello Roberto
This issue has been reported already before and the conclusion our team drew on investigating this was that, the issue is not with SpaceClaim but instead with the third party application being used.
Opening the .dwg in DWG TrueView shows the correct length.
May 30, 2019 at 9:46 am
rg
SubscriberSubashni I need it to release it to the customer so he can follow the progress of the situation
May 21, 2019 at 7:20 am
rg
SubscriberSubashni You could give me a bug identification number
Thank you
May 31, 2019 at 5:23 am
This issue was reported by another customer and the discussion on it came to a conclusion that the problem occurs only with one particular format and hence the issue must most likely be with the other application and hence a BUG was not filed for SpaceClaim.
June 3, 2019 at 6:52 am
rg
SubscriberHi, so could it be that the SpaceClaim dwg or dxf output format does not communicate well with some software?
Subashni
June 3, 2019 at 10:42 am
rg
SubscriberI'll use DWG TrueView , is corect
June 3, 2019 at 11:40 am
Ansys EmployeeRoberto
To the best of my knowledge, this same case was discussed with your colleague, Marco Checcoli via SpaceClaim support and even the conclusion was the same.
Using Autodesk DWG TrueView could not reproduce the issue. Thereby, proving that the issue is with the other application and not SpaceClaim.
June 3, 2019 at 12:50 pm
rg
SubscriberYes I understand you thank you
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Discovery AIM Mesh Error
- Natural frequencies limited to first 6 modes
3744
2573
1821
1236
596
