March 5, 2023 at 4:04 pm
DetroitKiddo
SubscriberHello all,
I have a question relating to scaling up an inlet boundary condition. I have two models I am trying to simulate with different inlet areas which I will explain in detail to clarify my question.
My first model has an inlet area of 602 mm^2 with a inlet velocity of 0.00000968992248 m/s.
My second model has an inlet area of 402 mm^2. My goal is to scale up model 2's inlet to the the same inlet velocity as the 602 mm^2 inlet. Basically with my second model due to CAD restrictions my inlet size is stuck at 402 mm^2. I cannot increase it to match model 1. So since I cannot scale the dimensional size I would like input a velocity that would give me the same velocity/area as model 1 so they are equal. Is this possible in ansys with a simple ratio formula ? Is there a way to calculate this new velocity so they both match and account for the scale up ?
Thank you all for the help!
March 6, 2023 at 7:26 am
SRP
SubscriberHi,
Reynolds number can remain constant in both scenarios. After that, try to determine the velocity for the second scenario.
Thank you
March 6, 2023 at 4:33 pm
DetroitKiddo
SubscriberHello SRP,
I checked the velocity being produced for the second model and it is different so I am not sure how to assign the correct velocity value to match the output correct if you can clarify that part from your reply. Thank you
March 7, 2023 at 4:31 pm
Ansys EmployeeAre you trying to match mass flow? Or velocity?
March 7, 2023 at 4:39 pm
DetroitKiddo
SubscriberHello Rob,
I can match either one it does not matter on my end. The mass flow rate into the 602 mm^2 inlet area is 0.00000581 kg/s. If there is a way to scale it and match this same flow for the 402 mm^2 thats fine. Either mass flow or velocity both would be fine as long as I can scale it correct so both surface areas are producing the same inlet flow into the domain. Thank you for your reply Rob!
March 7, 2023 at 4:49 pm
Ansys EmployeeThen why don't you scale by area? It's a relatively simple calculation on paper. If you're not sure, ask your Prof.
3862
2635
1859
1254
600
