Photonics
Photonics
scat far-field from a particle on substrate
    • ferruccio.pisanello
      I have confusion related to scat far-field calculation as explained in the example.
      https://optics.ansys.com/hc/en-us/articles/4403945613843-Polar-plot-of-scattered-field-with-particle-on-substrate
      Why the polar angle theta is defined from -90 to 90 for scat far-field conversion to spherical coordinates using the function farfieldspherical()?
      However, as explained in the following article the coordinte limits for polar angle theta are from 0 to 180.
      https://optics.ansys.com/hc/en-us/articles/360034394294-Understanding-direction-unit-vector-coordinates-in-far-field-projections
      This creates confusion in interpreting the far-field pattern.
      Regards
      FK
    • Guilin Sun
      You are right. A better definition should be from -90 deg to +90 deg, with zero along the monitor normal, which is what is used in the script. Otherwise it is hard to interpret the result.
      Hi, Thanks for your answer.
      If we have a monitor in XY plane(cartesian), then to calculate far-field XZ and YZ domain we should set angle phi as 0 and +90, respectively in the following function?
      E_ff_polar = farfieldspherical(E_ff,ux,uz,theta,phi);
      and to see polar FF in XY plane, the following should be the way?
      theta = linspace(-90,90,180);
      phi = linspace(0,360,360);
      Theta = meshgridx(theta,phi);
      Phi = meshgridy(theta,phi);
      E_ff_polar = farfieldspherical(E_ff,ux,uy,Theta,Phi);
      E_ff_polar = reshape(E2_angle, [length(theta), length(phi)]);
      theta_polar = 0; # what should be this angle for XY plane 0 or 90?
      E_ff_polar = E_ff_polar(theta_polar,:)
      polar(phi/180*pi,E_ff_polar);
      legend("XY plane");
      The function reshape(), here gives noise at the corners?
      And how do we interpret the direction of the angle from the polar plot for a given XY, XZ or YZ domain? Will the conventions explained in the Mie scattering example (section Far-field angular scattering) in the following article be valid here as well?
      https://optics.ansys.com/hc/en-us/articles/360042703433
      Regards
      FK
    • Guilin Sun
      Farfield projections in 2D and 3D are different, where 2D plot is polar but 3D is on the semi-sphere with theta and phi (spherical coordinate system). If you want to plot XZ or YZ farfield, you can set up angle
      But if you want to get the cut in the 3D result, it is not easy.
      You can simply use the previous file, whether it is xz or yz.
      I got a bit confused.
      As explained in the following article.
      There is a monitor in the XY plane and it calculates a 3D FF in the form of a semi-sphere using
      E2=farfield3d(mname,1,res,res);
      Then by using  % E_ff_polar = farfieldspherical(E2,ux,uy,theta,phi);% and setting phi = 0, we can get the 2D FF in the XZ plane. Right?
      So, from your answer, I got that this 2D FF in the XZ plane is not the xz cut of FF semi-sphere calculated by farfield3d(). Is that true?
      Regards
      FK
    • Guilin Sun
      You can get phi=0, or other phi values. But I do not think  it is the same as the 2D plane you want. Please test and compare the results: directly do the 2D and extract 2D data from 3D.
      One more thing to think: polar plot requires angles from 0 to 360. But theta is from -90 to 90 deg for a given phi, how can you plot it in polar?
      Hi, thanks for your answer.
      How I can directly get a 2D FF? because recording a near field with a 2D monitor and then getting FF from it by using the farfield3d() function gives semi-spherical 3D FF? then one can extract 2D FF by selecting a phi.
      I think, this is what is explained by this following example? No?
      "One more thing to think: polar plot requires angles from 0 to 360. But theta is from -90 to 90 deg for a given phi, how can you plot it in polar?"
      That's what I am also wondering because this is how it's explained in the example. They are plotting the polar plot with polarplot(theta, E2) at a given phi that's why we can see the values only in half plane of the polar plot.  And if we change the angle theta from -90:+90 to 0:180, the same pattern rotates by 90.
      Regards
      FK
    • Guilin Sun
      It is indeed confusing. You can plot the far field in spherical coordinate like this:
      polarimage(ux,uy,E2);
      Phi is from 0 to 360 deg and theta is from -90 to 90. So how can you cut the image into a 2D polar plot? phi=0 is only from theta from 0 to 90, and phi=180 gives theta from -90 to 0.
      There is a little complicated, subtle issue here. If you have premium support previledge, please send us support ticket for more.
      Or simply use
      to plot the 3D result.
      Hi, Thanks for the answer.
      We have an active license but I don't know if we have a premium support privilege. How can we know if we have a premium support privilege or not? Thanks!
      Regards
      FK
Viewing 8 reply threads
