Discovery Import
Discovery Import
SCDM and Discovery results are different
    • jgshin
      When I use the Interference Tool, the results are different. I used SCDM example model(Turbo Charger) and Ansys Discovery 2021R1&R2. Please check the attached files.
    • Devendra Badgujar
      Hi JUGYEONG SHIN
      I am looking into it and will get back to you soon.
      Regards.
    • Devendra Badgujar
      Hi JUGYEONG SHIN I checked this example model (Turbo Charger) from my end in both Ansys SpaceClaim and Ansys Discovery 2021 R1 as well as 2021 R2  version and I did not find any difference in the results while using the Interference Tool. Please check the attached files. The error may be in the example model file that you are importing, Please can you share that file with me so that I can check it at my end. Regards.
      • jgshin
        Hi Devendra Thank you for your answer :) Please check the attached file. For reference, my colleague had the same problem.
        🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Devendra Badgujar
      Hi JUGYEONG SHIN
      I also found this problem but it is specific to only model file that you sent me.
      I have reported a bug for this issue. Bug number 529623.
      Regards.
Viewing 3 reply threads
