May 4, 2023 at 3:35 pm
Jake Garrison
SubscriberHello,
I have a parametric inventor model that is loaded into Spaceclaim and Modified to be 2D geometry as shown below.
Using SCDM scripting in python, how can I find the flats (edges) on the nut geometry that contact the bolt flats (edges) and create named selections for each pair. For example:
Named selections for the first thread shown above.
Named selections for the second set of threads shown above, Etc.
I can calculate the length of the flats from the pitch on the bolt and nut threads, in this case they’re 0.111" in length.
May 5, 2023 at 10:06 am
Aniket
Ansys Employeeyou can use PowerSelection APIs to filter all edges with the same length (note this is what it records in the script editor when I select one edge in the tree, and then from the "selection" tab choose "select edges with same length", and insert selection in the script editor):
PowerSelection.Edges.ByLength(EdgeSelection.Create(GetRootPart().Bodies[0].Edges[2]),
PowerSelectOptions(True), #true if you want to search across all bodies, false if you want to search only in the bodies[0]
SearchCriteria.SizeComparison.Equal)now you can get 2 selections for same length, you can pythonically loop in one group of edges, to find if there is another edge coincident with it:
for example:
GetRootPart().Bodies[0].Edges[3].Shape.Geometry.IsCoincident(GetRootPart().Bodies[1].Edges[0].Shape.Geometry)
-Aniket
May 5, 2023 at 3:03 pm
May 8, 2023 at 10:18 am
Aniket
Ansys Employee -
May 8, 2023 at 12:17 pm
Jake Garrison
SubscriberNo they are not coincident.
May 9, 2023 at 8:31 am
Aniket
Ansys EmployeeIsCoincident will only work if the edges are coincident. If they are not, you may have to try and check the bounding box of these edges and then decide this.
You can get a bounding box by:
e1=GetRootPart().Bodies[0].Edges[0]
b1=e1.Shape.GetBoundingBox(Matrix.Identity)
b1.Center
b1.corner
-Aniket
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5454
3419
2473
1310
1022
