Scheme file and TUI problem
    • ceko
      Hi everyone,
      i'm using a scheme file to set a menu in fluent this menu name is PID ( in yellow) and present like :
      As you can see i can not set the input parameter but when i check in fluent i can see it :
      The drop down list for the iput parameters doesn't work.
      my scheme file code is too long and i can't put it as an attachement but i think it's an interface prbleme :
      Someone can help me ? Or do you know how use an input parameter in a procedure scheme ?
      Thank's it's urgent
    • RK
      Please check this section of the user's manual :Chapter 4: Adding Menus to the Right of the Ribbon (ansys.com)
      Subsequent sections also have comprehensive examples.
