3D Design
3D Design
Script Commands for facethickness
    • KnHw
      I want to change the thickness of some faces of my shellbody. Therefore i wrote script, wich creates the faces. Now i want to give them a variable thickness. I know that i can do it by hand changing the thickness in the face properties, also it is possible, to parameterezise the thickness there. But because i used a script to generate the body and this is not recorded, ansys losses this settings, when i change the geometric parameters for my parametric study
      I also tried to use the midsurface tool, for solid elements, but this didnt't generated the correct faces. Thats why i build the faces on my own with the scirpt. So Midsurface tool is not a working solution at the moment
      I hope someone have a hint for me.
      Thank you very much
      Best regards
      KnHw
    • Aniket
      surfBody=GetRootPart().GetAllBodies()[0]
      thickness=MM(1)
      MidSurfaceAspect.Create(surfBody, thickness)
      -Aniket
    • KnHw
      Hello Aniket,
      thanks for your help. This one solve a part of my problem. I think i need to understand the surfBody=GetRootPart().GetAllBodies()[0]  command a bit more in detail. I have some faces, wich i also want to set a different thickness, in a component. It is possible to select all these faces in the component? I wrote something like surfBody=GetRootPart().Components.Content.GetAllBodies()[0] but it didn't work. Another idea if i can select just on face in the component section i could wirte a for-loop. But i got the solver output: expected DesignBody, got DesignBodyGeneral. Maybe you could explain to me the difference or give me a link where i can reread it in the spaceclaim manual
      But overall thank you, you made my day by this hint. I have to complete my thesis sone and this hint showed that my simulation could work
      Greatings
      KnHw
