Photonics
Photonics
Script to calculate refractive index vs Temperature plot
    • Anindya Bose
      Dear Experts,
      Is there any FEEM program script available that can convert voltage vs temperature data into temperature vs refractive index data? Any help regarding this will be highly appreciated.
      Thanks and regards,
      Anindya Bose
    • Guilin Sun
      Please refer to this example: https://optics.ansys.com/hc/en-us/articles/360042338014-Thermally-tuned-waveguide-FEEM-
      once you import the temperature data (attribute) with given voltage, you can sweep the voltage or voltage point. Then you can get neff as a function of voltage. However it is not with temperature, as the temperature is a spatial distribution and it is not a single value at each voltage.
      Please check the example and see if you can duplicate the result, and then modify it to fit your need.
    • Anindya Bose
      Dear Expert,
      In this link, I can only see one script and that is to produce the file T.mat which is written below.
      temperature=getsweepresult("sweep","T");
      matlabsave("T.mat",temperature);
      However after producing the T.mat, I don't see any further script or ways to reupload or import the T.mat file in FEEM solver to execute Voltage vs refractive index plot.
      Can you please look into this and tell me a ways to resolve the matter.
      Thanks and regards,
      Anindya Bose
    • Anindya Bose
      Dear Expert,
      I could not be able to see the refractive index as a function of voltage in FEEM but I have plotted the refractive index as a function of voltage using mode solution. Is there any way to see the real and imaginary parts of the refractive index separately as a function of voltage?
      Thanks and regards,
      Anindya Bose
Viewing 3 reply threads
