3D Design
3D Design
Scripted GDS Import in SpaceClaim
    • peteb92
      currently I want to automate the import process of a GDS file in SpaceClaim.
      I am using an IronPython Script to set up a system in ANSYS Workbench. As geometry of the system I want to import a GDS file in SpaceClaim. I could not find anything related to that in the API, nor in other posts. Is this even possible via script?
      Edit: It is possible to open a GDS file manually. Then there is pop-up note saying AnsTranslator succesfully translated the GDS file to something readable by SpaceClaim. Is it possible to use the translator to automatically translate the GDS before opening it in SpaceClaim?
    • Keyur Kanade
      Go to file --> new --> script.
      Here you can record the steps you are doing manually. Then you can use those commands.
      Keyur
    • peteb92
      This does not work when I am using the IronPython from Workbench. I need to execute the commands from Workbench and Workbench Macro Recorder does not record macros in SpaceClaim.
    • Keyur Kanade
      I will check with expert if he can comment here
Viewing 3 reply threads
