Discovery Import
Discovery Import
Scripting
    • Guillaume ANFOSSI
      I am looking for the command in scripting to find the distance between two origins (local in a component compared to the origin of the assembly). Is it possible ?
      Thanks.
    • Naresh Patre
      Hello GUICAD
      Below is a simple script to get the distance of local coordinate system w.r.t global origin:
      import math
      part = GetRootPart()
      #access local coordinate system
      temp = part.CoordinateSystems[0]
      #access origin of coordinate system
      a = temp.Frame.Origin
      print a
      #note - the values of origin are returned in Meter units
      #calculate distance from global origin
      dist = math.sqrt((a[0]*a[0])+(a[1]*a[1])+(a[2]*a[2]))
      print dist
    • Guillaume ANFOSSI
      Thanks Naresh !
